SLC, UT
6/27/2018 8:59pm
My…maybe 10 year old(?) gas can developed a leak—any reason to go with one of the cans everyone at the track seems to use? What's the advantage over a more traditional can?
I haven't heard about the plastic contaminating the fuel, but I suppose it's possible.
Here in CA, it's illegal to store fuel in anything except a government-approved can, which of course does not work as well as a VP-style one. The state, in its infinite wisdom, intended to create a spill-proof can. What they managed to design was a can that without fail, will always spill fuel. It is literally impossible to use a CA gas can without losing fuel. And yes, I know how to use the word "literally."
Before I go riding I dump any gas remaining in the can in my truck and then get a few gallons to ride with. I also use this gas for my other power equipment, pretty much use premium in everything now. 1 gas can for everything and if you do as I said above it's always fresh gas.
I use mine on an IMS 3 gallon tank and it fills it up basically to the brim. If I want to completely fill it up I lean it to the side just a little while depressed.
They have 3 and 5 gallon cans. The 5 when full can be a little unwieldy but not horrible. If I was filling bikes up all the time I would consider a 3 gallon for that reason. But once a week for a trail ride, the 5 gallon works best for me.
Moral of the story. I was about to buy a new can at Wal-Mart the other day for lawn mower gas...I couldn't figure out how to use it, thought I was going to break it. I didn't buy one, will probably just try to get another VP style can.
in Ca that is.
but the design seems to be white labeled under a few different others as well.
http://www.tuffjug.com
The funnel is attached and this thing is so easy to use. I have yet to spill a drop. I will never store gas in a plastic can again. And don't forget the stabilizer!
https://www.amazon.com/Eagle-UI-50-FS-Galvanized-Gasoline-Capacity/dp/B…
1- 37
2 -180
3 - 2600
4 - 358
I've got a few of these and aside from pouring a little slow, no complaints.
Post a reply to: Advantage of VP-style gas cans?
