Fort Collins, CO
628th
I’m having problems with my 2018 yz250f clutch, unlike most clutches where when it gets hot and gains free play my clutch gets stiff even after adjusting the cable all the way in. The bike usually last about three motos until the clutch is completely burned up and I’m pushing the bike back to the truck. I have tried a rekluse and Hinson and currently have an oem one back in the bike and it lasted about 2 hours of riding before it went bad. Any advice helps thanks.
I also have a 17 Honda 450 and got 50 hours out of the clutch, and another bud has the same bike and would only get one race (4 motos and morning practice) he complained to Honda and they told him it was him not the bike
Are you sure you're putting it together properly?
Please describe your riding style, tracks and terrain you ride most often.
When I first start riding the Yamaha I replaced just the plates and the clutch went pretty fast, those parts are less than 100 bucks for the 125
Good luck
If both motors are the exact same build they should wear very similar. If your practice bikes clutch is good I would pull the full clutch,arm assembly, rod, ball and top hat from your practice bike and switch it to the race bike and see.
Going by what you said it doesn't sound like the clutch basket, hub or plate. Have you changed the cable I have seen defective cables cause odd issues. Both from oem and aftermarket. I had a motion pro one time cause the bike to act like the clutch had broken plates. Ran fine from low to mid but from mid up it just reved like the clutch was pulled in. Threw the stock junk cable back on and it was fine. Also had a oem cable turn out to be almost 1/2 inch short. Constant clutch fade.
I bet your pressure plate has grooves or it is worn as well as the hub. Change them problem solved
What oil are you using?
I put an ARC perch/lever on mine before I ever rode the bike and never had a problem.
I do agree the clutch must be consistently slipping to cause it to burn up in 2 hours.
Post a reply to: 2018 YZ 250f Clutch problems
