2005 cr250 leaking oil
5/1/2018 12:22 PM
I just bought a 2005 cr 250 that has been sitting up for 3 years. The bike is in great condition and appears to not have many hours on it. After changing the trans oil and starting it there is trans oil leaking from the weep hole on the bottom of the case? Any help would be appreciated thanks
5/1/2018 12:23 PM
Exactly what weep hole? If its by the waterpump it needs new seals
5/1/2018 12:27 PM
Edited Date/Time: 5/1/2018 12:28 PM
There s a weep hole for the water pump but that would be the only one that is designed to be there on purpose. Take a pic and attach it for further diagnosis
Was once there, now old, fat and tired... require much more horsepower now...
5/1/2018 5:45 PM
5/1/2018 9:19 PM
Shoot that old turd and put it out of its misery.
5/1/2018 10:21 PM
Edited Date/Time: 5/1/2018 10:36 PM
If the oil seal on the clutch actuating arm leading into the case is bad, it would let oil into the side case and out that hole.
Looks like you'll want to make sure your case breather hose isn't clogged as well or it will keep happening
https://m.vitalmx.com/forums/Race-Shop,42/03-CR250R-Leaking-Transmission-Oil-From-Weep-Hole,1307558
5/2/2018 7:02 AM
Much ty
5/2/2018 7:09 AM
Clutch arm seal looks to be ok and the crankcase breather hose isn't clogged.
