Fredericksburg, VA
10/18/2022 6:50am
Hey guys just thought I'd share my latest 2-stroke project. I picked up this 04 rm 125 for cheap - it had just been rebuilt, but as you can see was in pretty bad shape. It was a diamond in the rough though as most bearing were great, suspension was tight with no leaks, and the bike felt like it was not ridden hard (just not maintained) the kicker, footpegs, shifter, brake pedal, etc all felt showroom tight.
I got it home, and pressure washed it and then hit it with acid wash.
Next I tore it down to nuts and bolts. Sandblasted frame and used an epoxy black on it, with a 2 part urethane clear. I didn't want to dump a ton into powder because down here in VA I couldn't get a half decent price.
Polished the outside of the tranny cases. Sandblasted the clutch and ignition covers then acid washed them to turn them a brown color.
I found the stock color pink/ clear carb vent hoses.
When I tore the bike down I noticed a scratch in the cylinder. I checked the crank for tolerance, and it was great. I flushed the bottom end just in case. Ended up sending the cylinder to Powerseal USA - those guys were great, and quick.
I went with a Pro Circuit works pipe, r-304 silencer.
Got a full acerbis plastic kit with the 2013 front fender and plate. All new bearings, cables, throttle tube. Chain, sprockets, and bars are pro taper. New brake pads front and rear.
I had new stock excels powder coated black.
And here it is, done. A set of MX-51's's on it now it's ready to go. I didn't mess with suspension since the bike is for sale, I'd rather let people do what they want with it.
Here's the final pics, let me know what you think!
That is one of the nicest transformations on a Vital rebuild I have seen.
I would like to nominate this steed, for the VitalMX 'Bike of the Month.'
Thanks for all the positive comments guys! I was going to add it into bike checks tomorrow.
We're a bit sadistic when you think about it... I would spend hours with a pack of Q-Tip's and a Toothbrush, getting every last bit of dirt I could without pulling the bike apart, (completely). Then you enjoy getting the thing dirty!
And how much did you put into it
For the fender, the rear bolt holes for almost perfect, I just had to elongate them a bit. After that I had to drill two new front holes. After fitting the fender the front inner plate actually just fit on perfectly like it was made for it.
Very nice job on on the transformation, great work!
Im in the process of doing the same thing with a RM250, check out the thread in the Race shop forum if you wish.
What did you use to polish the cases??
Thanks
Post a reply to: 2004 RM 125 Project - Finished
