Weatherford, TX
10/6/2012 1:38am
I posted this in the jumping back to 2 stroke thread. That thread is pretty well dead so I decided to start a new thread so I can get some feedback on this.
I have been curious as to what the manuals say about top end replacements on the two versus the four stroke since many people complain about how many top ends they had to do on their two strokes. My 05 YZ250 manual says to replace the piston every fifth race and rings every third race. My buddies 07 YZ450 manual says to replace the piston and rings every fifth race. Sounds to me like the top ends should basically be done at the same intervals, plus the four strokes have the valvetrain to consider. Given this, how could a four stroke not be more expensive, over time, when considering the valvetrain components will eventually need replacing? Just curious.
It cost me maybe $160.00 in parts with a piston.
A novice beginner should be able to ride a 450 for 2 to 3 years for about $500 in motor parts if regular maintenance is done.
Besides the normal maintenance on any bike. I just put usually one top end during that time(piston and rings).
Which that recipe. I've figured out I get to work on my bike the least and ride it the most while saving the maximum amount of money.
I've always had to put top end in my 2 strokes more often. I would rather ride longer during service intervals and I prefer a 450 for other reasons too.
The main reason why the 125's dont last as long is because you have to rev the ever living shit out of them in mx and just about anywhere. And they only have 1 ring.
250 2 strokes last alot longer because not as hard riding on them. i's say the cheapest bike for maitnence is a 250 2 stroke or a higher cc 2 stroke. But as stated above if you keep the 4 strokes in good maitnence with fresh oil/oil filter and air filter it will last you quite awhile. especially if its a yamadawg
I have had 5 YZ125s and never had that issue so I was wondering what was the cause. But I have heard the horror stories about the Athena kits.
I am thinking about doing the Gorr 144 kit on my 04 YZ125 but not sure about pulling the trigger on it just yet.
Have you notced that you have to ride the 125 a bit harder than the 450? Do you suppose that the 450's 325cc displacement advantage might factor into this somehow?
Up next: FORD F350 vs Honda Civic towing capacity.
Post a reply to: 2 stroke vs 4 stroke maintenance
