Does anyone know if a 88 cr500 engine would bolt in a 92 chassis?
I know the pipe is different on the 88, would the 92 pipe work on the 88 engine?
Any advice would be appreciated
I can get my hands on a full 92 rolling chassis with pipe and carb and a complete 88 engine
Are here any CR500 forums?
The cylinders and heads went thru some changes: ports, squish area...etc. I believe the cases stayed virtually the same?
+ As everybody said. (it is a 500 !, and the 85-86 have some differences (rod, cylinder cooling, etc) and still bolt in, and the 87-2001 remained the same except some very minor changes like the low boy pipe you get with your rolling chassis).
The cooling circuit is different, the water pump and right cooling hose will mess with the low boy pipe.
Can be fixed but needs quite some work, needs another water pump and machining/welding on the cylinder.
Post a reply to: 1988 Cr500 engine in a 1992 chassis
