St. Petersburg, FL
cdoggy81
3/1/2021 9:22pm
3/1/2021 9:22pm
7/29/2022 3:48pm
As the title states I have a mint Kashima coated KYB 50mm shock body. Top bearing was for Yamaha. If you need a 52mm bladder or compression adjuster I can help you out. Also have a DLC shaft & a 5.5 spring if you need that too. Open to reasonable offers as I would rather see someone use it vs sit on my bench. There is zero wear on the shock as it was a spare from a Yamaha backed race team from a few years ago. Does have a few little exterior nicks from being moved around over the years.
Will trade for other cool parts or yz125 / yz250 items.
Thanks
Thanks
I believe this batch came with 2014-2015 parts to be more specific.
$25 for a compression adjuster
$175 16mm shock shaft
$sold 18mm shock shaft
(1) Will this shock body work on a 2020 YZ450F? Sorry if this is a dumb question - I'm pretty ignorant on specialty suspension parts.
(2) The 18-mm shaft looks to be DLC, yes? Also in mint condition?
I might consider this for having ENZO build me up an A-kit shock.
2 - yes DLC. However if you want this for your bike the new ones went back to 16mm. If you want a 16mm I have one of those too.
If you want to build up your shock I also have a spare Enzo Technica rear shock compression adjuster as well.
Thanks & happy 4th!
16mm shaft available
18mm shaft sold
$100 shipped with black anodized bladder
$125 shipped with above plus a compression adjuster
Post a reply to: Kashima coated KYB 50mm a-kit shock body
