Edited Date/Time:
Lots of parts for the 16-19 KTM SXF SX EXC and Husqvarna FC FX TC
16-18 KTM
Subframe $150
Complete seats $125
Fuel pump used $250
Fuel pump new $300
OEM Triple Clamps $125
Neken triple Clamps new (not air) $350
Neken triple Clamps used (not air) $250
New PHDS bar mounts $150
New Neken handlebars $40
New Pro Taper handlebars $40
Aluminum throttle tubes $30
New OEM throttle cables $70
Complete Brembo front brake assembly $200
New Brembo brake pads rear $50
New Brembo brake pads front $60
New OEM footpegs $40
Used OEM footpegs $30
IMS Core MX new footpegs $125
IMS Core MX Used footpegs $80
Used shifter $25
New shifter $40
New rear brake lever $40
New rear brake spring $5
250 and 450 radiator sets $150 each set
Throttle body $250
Wire harness $125
Condenser $40
Rectifier $30
Tip over sensor $15
Kill switch $25
Engine start button $30
17-19 map selector assembly $50
New Brembo clutch master cylinder $200
Used Brembo master cylinder $125
New clutch cable $25
New clutch slave $100
New clutch slave piston $50
New Brembo clutch lever $30
New ODI grips $15
Front axle $20
Rear axle and spacers and nut $30
Swingarm pivot bolt $15
Linkage and cam with bearings $100
Linkage bolts and nuts $30
Swingarm $125
Air boot $40
New front sprocket guard / chain catcher $20
New chain guide $25
New chain slider upper and lower $30
New ECU $200
WP new rear OEM shock $450
WP factory connection shock $500
Complete Brembo rear brake assembly $150
Large front axles $24
16 engine mounts $25
17-18 engine mounts $30
Front rotors OEM $50
Rear rotors OEM $40
New 270 Galfer tsunami front rotor $200
New Galfer rear rotor $70
New OEM 51T rear sprocket $50
New Sunstar 13T front sprocket $15
New OEM lower fork guards $20 (small axle and large axle)
‘13-15 250/350 Engine cases $400
‘13-15 250/350 ignition covers $100 (cerokoted grey)
‘16-18 450 Engine cases, set $500
500cc new OEM crank SXF EXC 16-18 $650
Complete engine from 2017 (10 hours) $3500
Complete 250 engine 2017 full Twisted engine with Factory services transmission $4500
Complete race engine 2017 full Twisted Development treatment and Factory Services transmission ($7800 in mods to engine) $4500
Engines fit KTM and Husqvarna
KTM 2019
New Acerbis full plastic kit OEM colors $150
Complete OEM seat (5 hours) $125
OEM Exhaust $125
New black frame guards $25
Husqvarna 16-18 FC FX
New fuel tank $150
Used fuel tank $100
New white OEM fuel tank $150
Used white fuel tank $100
IMS 2.8 gallon fuel tank (white with dry break top $250
16 and 17 450 frames with fresh powdercoating $500 with title (white and black)
16 250 frame with fresh powdercoating $500 with title (black)
Composite subframe and air box $250
New OEM front fender $20
New OEM front number plate $20
New OEM rear fender $30
One time use side panels $30
Chad Reed Plastic and graphics kit (minus front plate and fork guards) $100
Complete new OEM seats $150
Complete seats with Guts black rubber seat covers $150 (regular foam, tall foam, or regular with hump)
The only parts that don’t fit on the Husqvarna from KTM are
Seat
Fuel tank
Subframe
Air box
Front sprocket guard
All plastic (except lower fork guards)
Please call, text or email
(714) 351-2627
Tcgravitt@hotmail.com
please contact at (714) 351-2627
