Edited Date/Time:
Hi VitalMX'ers,
I'm going old-school and building a nice, MX-oriented (but fully capable for off-road, too) 2008 Honda CRF450R for myself.
Quickly, here's how I've built it thus far:
-Factory Connection suspension revalve for Vet Int/Expert, focus on plushness and staying up in stroke
-Framebreaker Racing carbon fiber air subtanks (with built-in bleeders)
-Xtrig shock-preload adjuster
-Zip-Ty Racing carb mods performed (includes magnetic drain plug)
-R&D Racing Power Bowl 2 (gray in color)
-R&D Racing Flex Jet remote fuel-screw adjuster
-Dubach Racing NS-4 full exhaust system
-FMF Snap carb insert
-ARC RC-8 clutch perch assembly (black composite lever)
-ARC front brake lever (black composite lever)
-Motion Pro T3 Slidelight clutch cable
-Motion Pro T3 Slidelight hot-start cable
-Motion Pro Titan throttle tube
-Renthal full diamond grips, firm compound
-FasstCo Flexxbars (14-deg bend)
-FasstCo Impact pegs
-PMB Kick-It kickstand
-SDG step gripper seat
-Rekluse Core EXP 3.0 clutch
-Steahly +11 oz flywheel weight
-Wiseco lifetime-warranty forged clutch basket
-Galfer 270-mm front rotor setup
-Galfer stainless steel front brake line
-Galfer stainless steel rear brake line
-Scotts Performance Shark Fin
-Scotts Performance steering damper setup
-Dubach Racing radiator lowering kit
-Evans coolant
-CV4 silicone radiator hose kit
-Tusk Racing high-pressure radiator cap with temperature gauge
-Hammerhead CNC shift lever
-Hammerhead rear brake lever
-FasstCo rear-brake spring kit
-Cycra CRM Probend Handguards for Fasst Flexx Bars (with G2 Ergo threaded bar-end inserts)
-IMS 3.2 gallon tank (in natural/see-through color)
-Stegz Pegz (for better gripping of bike with boots)
-Nuetech Tubliss (tubeless) Gen 2.0 19" rear kit
-Ironman sprockets (14/48)
-Fastway Ring Leader Counter Shaft Spacer
-Regina Z-ring chain
-T.M. Designworks Factory Edition 2 Rear Chain Guide and Slider Kit
-T.M. Designworks case saver
-Hyde Racing plastic skid plate (to allow flex but also protect, less noise, too)
-Mino CNC'd clutch cable holder bracket (eliminates flex)
-Works Connection radiator guards
-Works Connection rear-caliper guard
-Works Connection hour meter
-Cycra Powerflow Plastics body kit
-Cycra oversize front rotor guard (to accept the 270-mm disc)
-Tusk Racing bling kit (anodized red engine oil fill plugs, steering stem nut, etc.)
-Tusk air filters
-Impact Graphics kit all around (I believe Tusk makes these)
-Motion Pro magnetic washer for use behind the OEM oil filter (to catch debris)
-Maxima Oils stainless steel oil filter, reusable
-I use Maxima Oils synthetic oils/fluids exclusively (engine oils, brake fluid, air filter oil/cleaner)
So, here's my question for you guys ...
Do you have any 2008 CRF450R compatible performance parts you think I've missed? Anything you want to sell me? Ignitions, other?
Thanks for reading!
Contact me at: VitalMX123@outlook.com
