Merced, CA
12/24/2019 3:24am
Let me know what you need i have most everything for the bike clutch hand bars shocks rear sway bar spring radiators. Everything I don’t need hit me up
And no it's probably not worth fixing unless you plan on riding it yourself. The amount of money you spend on a head will likely be almost as much as the bike is worth unless you find a used one that's in good condition which is hard to tell without seeing it in person. But without it running it could have transmission problems. The first thing to do would be check the rod or crank for up and down play. If there's any even the slightest play when you Yank it straight up it's definitely not worth fixing. Some people might but not myself cuz then you need a whole bottom end and head and maybe top end. Also take the cylinder off and inspect the piston and cylinder, that will be easy since the head is already off. if you want to report back with some pics even though this isn't the proper area for a build I'm sure some people will help you out and tell you whether it's worth it or not.
Post a reply to: 2003 YZ 250 Parts
