Scottsdale, AZ
6/28/2021 12:14pm
Our brand new 2021 electric 50 has not been reliable, leaving my son without a Moto to ride on 2 of the 5 days we had planned to go riding. We returned it to the dealer the first time after experiencing the problem and will now have to again. Not confident in what the outcome might be at this point. Looking forward to the dealer’s and KTM’s response however, the lost opportunity and disappointment caused is not what I bargained for.
After we got home and washed the bike we now have blink code 39 which isn't even listed in the manual or anywhere online.
Will be taking it in to the dealer today but I'm pretty disappointed with this bike after hearing and seeing so many issues this weekend.
After that I decided to start taking things apart and after removing the motor housing on the right hand side of the bike, water actually came pouring out. I then blew compressed air all over and around the exposed circuit board and let the bike sit in with the cover off in the hot sun for 4 hours. After that I turned it back on and it worked.
To get the old error code to go away, I initiate the start up sequence, shut it down and do strange things like holding the button down, and turning it off in the middle of the startup sequence about 5-10 times before it will finally "reset" itself and try again without just throwing the same old code as the time before (this could all just be superstition too but it works for me).
After getting the bike to run again, I talked to an electrical engineer at work who told me how to clean the circuit board.
1.) Move bike to room in house with dehumidifier (I got the room down to 30% relative humidity for 24hours, the lower the better)
2.) Clean circuit board (used 91% isopropyl alcohol in a small spray bottle and sprayed it all over)
3.) Let dry for a couple of hours
4.) Spray circuit board with a conforming coat aerosol spray (419D-340G)
5.) Let dry and replace motor housing
6.) Take apart all connections, clean with isopropyl alcohol and wire brush, then apply dielectric grease to all of them (https://www.youtube.com/watch?v=EwAKR5kJuHk --> Link I used to figure out how to take everything apart)
After doing all of that, I have occasionally gotten an error code 73 and as I understand it, that could be from dirt in the charging plug or on the battery port. But, after blowing both of them out, making sure the bike is fully charged before removing the charger & turning the bike off before unplugging the charger - I have not had any more issues.
It's a shame that these bikes have so many electrical blink code issues because aside from those they are great. I just wish KTM had actual support for us so we weren't stuck trying to figure all of these things out on our own.
Last, there is a Facebook group for these bikes "KTM SXe5" that many people belong to and share all sorts of information, I'd highly recommend you join. I've also posted the majority of what's above to that group as well in case someone else runs into the same issue as me.
Also, for everyone that is looking for it you can now get repair manuals here.
https://print.ktm.com/
That being said the motor is not intended to be serviceable and there is no information in regards to removing the right side cover and reinstalling the cover.
I thought I once saw a cutaway on the motor when this bike was released and that would give some more insight on what is all going on but I'm assuming the the speed controller is housed beneath that cover.
This obviously is not the most desirable situation BUT since cleaning & coating the board as well as taking apart all connections I could find and applying di-electric grease the bike has ran great and I have had almost no blink code issues.
Here is a link to a picture of the motor (here). The blue color you see is the thermal material.
I am not an EE and know very little about what I am looking at on the circuit board, but felt like I was playing with house money performing these processes so all in all I'm pretty happy with how things have worked out so far.
Again everything above is just speculation as I am not an electrical engineer but it seems there is some type of interface material above in blue.
Also so everyone is aware of it there is a wash plug for the battery. Nilhilo Concepts sells it.
The Nihilo E-Bike Battery Vent Wash Plug was designed to keep unwanted water out of your battery. There is a small vented bolt on the back of the battery that allows air to get into the battery box, and the problem is if water gets in that vent it can do permanent damage to the battery. Nihilo developed these wash plugs for the KTM Junior Supercross bikes and has also made them available to the public.
Complete with a “Remove Before Flight” tag to remind you to remove it before riding. This simple little device will eliminate expensive battery damage and provide peace of mind that when you are washing the bike, water will not be able to get inside.
O-ring: KTM part # 0770170200
I searched the manual over after I saw this part and no mention of it is made in the 18 section of the manual. Just the generic language to avoid electrical components and connectors.... The whole bike is electric....
Thanks for the info!
I decided to bite the bullet and told the dealer to go ahead and swap the motor but the bearings were on back order until August 25th so I just went ahead and picked it up seeing there was no point of just leaving it at the shop until then. When I got home I did just as you did, took the right cover off the motor and it was wet inside. Blew it out and put it in a room with a dehumidifier and the code’s disappeared!
Now I just need to be able to find a front sprocket 😂
Thanks for the heads up on difficulty finding a front sprocket, I put two on order shortly after reading your post.
One of the main connections was not fully clipped together, it was deceiving because it had a ziptie from the factory still tight around the connector. One day it would'nt turn on so I checked all the connections and found the one was loose but the ziptie was keeping it from completely separating.
Post a reply to: KTM SX-E 5 Reliability Issues?
