DK
7/30/2022 11:02am
Hi all,
Im trying to reduce weight on my 450 husky 2022.
First of all i Will prioritize the rotation/undprung weight.
I need som help with the parts.
I already bought the schwalbe fat bike tubes which safe a lot of weight.
Next one it to buy hoosier tyres, as they are the lightest tyres as i Can see ?
I also bought titanium bolt for sprocket and rotors.
What Else is good money to spend $ on to reduce weight ? Im not sure if the rim lock on husky are the alloy one or the oem is as light as motionpro ?
Have anyone weighted the rear sprocket and Can tell which one is lighter than Stock ? And also the rotors? I Can see that motostuff should be 25% lighter on the back rotor - any Experience with that?
I Will also use money on the sprung weight if i Can gain a Big saving for small $. Dont Think Technology exits anymore ?
Our old saying with stock cars was “When you chase the ounces, the pounds will come.”
Where are you from ?
Are you sure that the weight saving is 100 gram compare to a Stock rotor from ktm/husky ?
I already bought akrapovic slip-on and that one saver around 1,2 lbs. I still ned the akrapovic titanium headpibe, but i dont know where to buy it seperate ?
No idea if Think! Is still around, but Guts has lightweight foam. Same seat/cover used on the Rockstar Husky’s.
(949) 444-4916
Let him know Shaun Langham sent you.
The go to guy for Titanium bolts/ hardware
Let him know I sent you, he may hook you up with a discount
https://youtu.be/7qByTK3SiBo
https://www.vitalmx.com/forums/Bike-Builds,46/2022-Husqvarna-FC450-Drea…
The bike weighs about 3lbs lighter than stock, which would've been closer to 7 or 8 if I didn't do the KYB spring forks, x-trig clamps, skid plate, twin walls, etc. It's still REALLY light compared to the last 450 I had (09 CRF). Hope this helps.
how is the forks compared to air ?
i can see that you're running CRM engine mounts. how mutch do you tighten them ?
The CRM mounts come with torque specs, but I don't remember them off hand.
Post a reply to: Trying to reduce weight on my 450 husky
