Run it down the frame and by the chain or between the swingarm.
Those bikes will spit oil out if the rings aren’t in great shape, you tip it over, or constantly on the rev limiter which will increase the crankcase pressure and push oil out. If your’s does, that’d be your best bet so it doesn’t fill the airbox. Try to not direct it on the chain otherwise it’ll throw it everywhere on the engine and rear fender.
If it doesn’t, you can improvise a little catch can or bottle to collect the oil and ziptie it on the frame somewhere.
