2007 kx 250f oil leak really need help
4/16/2018 9:51 PM
it is pouring oil out of the head gasket but not out of the cam chain side its on the opposite side it looks like it's coming out were the bolts are but not sure it has an oversized piston in it really need help.
thanks n
4/17/2018 8:05 AM
Edited Date/Time: 4/17/2018 8:07 AM
Sounds like it needs taken apart. Some bikes with oversized pistons require you to use a different gasket for that piston size. Maybe all it needs is some gaskets. Head bolts could be loose or the cylinder/head surface warped.
Are you sure your not talking about the valve cover gasket?
4/17/2018 9:50 AM
it has a moose racing gasket kit on it I think it's just a standard kit and i had the head shaved at a machine to be sure it wasn't warped. here's a picture of the leak Photo
4/17/2018 1:49 PM
Gasket in backwards? Or wrong gasket
RPM Performance
CT
783
4/17/2018 2:46 PM
You should reorder a new gasket and make sure it goes on correctly, with no damage.
You could probably get away with using so hi-temp sealant on the edges as well. It shouldn’t be pushing oil out like that.
Also, are you torqueing the bolts in a criss-cross pattern, bit by bit? You don’t want to tighten one down and then another. Do one til it’s finger tight, and crisscross. Then torque each one little by little to spec.
4/17/2018 2:52 PM
I will put it back together again and make sure everything is done perfect and this is my 2nd new head gasket
4/17/2018 3:34 PM
Then you may very well have a bigger issue. Possibly warped?
2017 RMZ450
2005 YZ250-sold :,(
1998 YZ250
2005 KX250F
IG @2HRacing
4/17/2018 5:36 PM
I took the head to a machine shop and had it cut down to be sure it wasn't so idk if that's my problem
4/17/2018 5:37 PM
it also has no power when I try pulling out
4/17/2018 6:21 PM
Oil pressure possibly? What happened prior to this? Any catastrophic failures?
4/17/2018 9:12 PM
I've seen that happen(the oil leak not the power loss, on a trx450 with a cometic base gasket, turned out they drilled the oil passage hole too small
4/17/2018 9:35 PM
I have no idea what this bike has been through I bought it from a guy a few months ago for a winter project it had a bent valve he said so I took it apart found that it needed a new valve and a new valve guide so I just bought a new set of valves an put a new guide in it put it back together and it has this oil leak so I put new rings and gasket kit in it still leaks so I thought maybe the head is warped and I had it shaved down and it still leaks not really sure what I'm gonna do at this point?
4/18/2018 3:44 PM
got it fixed head bolts needed to be at 35 foot pounds and I had them way less prob 20 and the Loss of power was my clutch cable needed to be loosed up so it wasn't able to engage. thanks y'all for all the help.Photo
4/18/2018 4:53 PM
Edited Date/Time: 4/18/2018 4:54 PM
Kaylee_Hale wrote:
got it fixed head bolts needed to be at 35 foot pounds and I had them way less prob 20 and the Loss of power was my clutch ...more
Your chain looks to tight
4/18/2018 6:36 PM
Also, stop riding on the road haha
4/19/2018 7:53 AM
your bike has no power because you have no tire haha.
4/19/2018 5:17 PM
I haven't actually got to ride this bike yet the guy before me must have liked to do burn outs lol and I will loosen the chain just waiting to pick up a new tire
