Rosemount, MN
6/20/2022 7:09pm
Was a long winter but finally done!
Engine: lectron Billetron carb, Apex head, pro circuit platinum 2 with TI-2 shorty, rekluse torq drive clutch, Vforce rad valve, 9oz flywheel weight, full rebuild using all Oem parts.
Chassis: Racetech gold valves and springs, 2009 Yz250f top clamp (adjustable holes), Faast bars, Faast rear master cylinder clevis, Flo lowered pegs, Rtech Revolution plastic kit, Carbon Fiber engine mounts, Honda CRF steering dampener, Galfer 270mm front disc and steel braided lines, Tusk wheels and Bridgestone tires, GUTS seat cover.
All bearings, seals, cables, etc.. replaced in engine and chassis. I did all powder coating/ ceramic coating on bike.
** yes I know the throttle cable is out of place and rubber is broke. It’s the old cable on right now while I tune carb- lots of twisting carb to adjust **
is dis true?
What tank is this ? Sweet build!!
Not my build but that's a Racetech kit.
Set Plastic Fairings Tank Yamaha YZ 125-250 Racetech Revolution Blue White | eBay
Post a reply to: 2007 YZ250 build
