Windber, PA
Halaburda120
12/8/2018 11:07am
12/8/2018 11:07am
I was thinking about doing a sss swap with my 2005 yz125. Will the 450f and 250f triple clamps and forks bolt right on to the frame? If not which years are bolt on?
I believe the rear shock on the 2005 and 2006 are different correct? So if I do the swap to make it correct I’ll need the shock too.
Am I best off doing the swap or just getting the suspension valved for my weight, skill level, etc?
If you have an 05, then you don’t need to change clamps. The 06+ forks will fit right up into the stock 05 clamps
Post a reply to: 2005 yz125 suspension help!
