Winnetka, CA
2monkeydoinsuspension
12/14/2020 6:28pm
12/14/2020 6:28pm
12/15/2020 6:30am
Hey guys, I am building a 2002 YZ125 with 46millimeter open cartridge forks . I live in Southern California and I only ride the tracks out here. I am planning on racing C group. What should my gold valve shim setting be? I am 5’10 and 165 pounds.
That said I've found most Novice riders like the dual stage setup over a single stage. Gives some plushness to the slower speeds the novice travel at (they hit more bumps). Just note that valving doesn't solve everything, spring for your weight and valving for the speed you travel. Oil height is how you tune bottoming resistance and those old KYB cartridge forks with the elastomer bottoming setup do well to be swapped out with a hydraulic style bottoming cone setup similar to what was found in the Kawasaki version of those forks. For your speed it will probably be fine but if you like to jump a lot the hydraulic setup is the better way to go IMO.
Stoked she went together solid 👍 looks like you did the assembly right based on the pics you sent.
Post a reply to: 2002 YZ125 Gold Valve Shim Setting
