Munford, TN
1/7/2020 11:15am
Bought a 2001 kx 125 for my son for Christmas he got maybe 3 hours on it and lost compression couldn’t even get 40psi it was low when I got it I believe it’s been a while since I kicked a 125 over so I just thought it was normal bc it fired up first kick every time but then it started to not want to kick we had to push start it before it went completely out I pulled cylinder and piston I will send pictures wondering if I can throw a new piston in and roll with it cylinder has been sleeved has one faint mark on cylinder but you can’t feel it and it has a wiesco position with 54mm std bore .. any help would be great trying to get this sad kid back up and going as fast as possible.. thank you
Most likely you will have to get it bored out to the next bigger size piston. Steel liners is oldschool tech if the piston is left in to long. The bore will wear and require a rebore to the next size to get things back into proper tolerances.
Post a reply to: 2001 kx 125 cylinder piston questions
