1998 YZ125 with 38MM carb?
Rickyisms
FL US
Helping a friend finish up his 98 YZ125 and he has a 38MM lectron to put on. We tried to use the boot from the 01 YZ125 which I believe is the first year 38MM, The boot is discontinued and can't get my hands on it even working at a shop. The boot from a 04 YZ125 still is avaliable (Assuming the 04 also used a 38MM carb), Would the 04 bolt pattern line up to the 98 cylinder?
11/21/2019 12:57pm
It might fit not sure if the angle is the same
That's where it's possibly different. hotfootmoto makes a reproduction of the 01 intake boot.
Premix
AS US
11/22/2019 12:09pm
Heat the boot up or boil it in water and slam it in there. I ran a Keihen 38 Air Stryker on my 97. You will have to play around with pilots and mains. Think I ran the DDJ needle. Makes the bike pull a little harder up top
YZed250
Costa Mesa, CA US
11/22/2019 2:48pm
I have a used 2005 boot for sale or available to take some measurements if you need them.
Post a reply to: 1998 YZ125 with 38MM carb?
