Cedar Rapids, IA
12/24/2019 12:56pm
I picked up this 1997 Honda Cr125 yesterday. I found a deal I couldn't pass up on the Facebook market place and it was about an hour from me. So, I hopped in my van and away we went! It was in a rough part of town that was pretty sketchy, but none the less I didn't die or get robbed. I had my trusty .45 with me for safe measures.
I couldn't hear the bike run but supposedly it did before the radiator cracked (and was also missing?) it turned over with good compression and went through all the gears so that was good enough for me since it would be getting tore completely down regardless.
I loaded it up and headed home to take some initial garage pictures for the followers (always a must)
I am not entirely sure where I want to go with this build but follow along and see where it ends up!
In the middle of the tear down process, everything came apart rather easily besides the linkage bearing connection to the frame. It took some effort. I don't think I found a single matching set of fasteners on the entire bike, new fasteners are in order.
The previous owner definitely got their moneys worth out of the chain roller...
Dropped the frame off for powder coat yesterday! I can't wait to get this bad boy back! The other frame is the kx125 frame from the build linked above.
Not the 2019 version that just came out, I wish it was!
I also purchased a buffer with a rubber expander wheel and I am going to try and make a scotch brite wheel for cleaning and removing casting marks. I can post more details on this setup and how it works!
I also purchased an ultrasonic cleaner for cleaning small parts and I will update on how it works once it arrives.
Lastly, I purchased a tumbler for cleaning and polishing old hardware.
All of these should arrive within the next week! I'll give some feedback so ask away, I can also post links to what Items I purchased if desired. I am most excited for the ultrasonic cleaner!
I should have my frame back today from powder coat!
I was able to get the front wheel dissembled by first soaking the nipples in Penetrating oil after cleaning, but unfortunately no luck with the rear as the spokes kept spinning in the hub so I had to cut them out with bolt cutters.
The chain slider and guide have seen better days!
I'll post up pictures of my carb later, but here is a mtb cassette I did for shits and giggles.
10L Ultrasonic cleaner, it was $120 on ebay
Shelf pistons are 57.94-96
So you can't use the shelf piston
I POSSIBLY have a gorr piston on the shelf - you can have it if I do
Thank you,
Chase
email me harrisperformance@gmail.com and ill get shipping address - you can have it for whatever fedex cost me
Post a reply to: 1997 CR125 Rebuild, Lamson Style
