- Pick trends
- Create a private league
- And more!
The details of the package a little later, thank you to him for his help in reassembling my 250 CR
Pfff you thought me ?? but no I'll tell you something, Santa Claus does not exist
In short we come almost to the end of all the missing pieces.
it's not essential, just to decorate the front fender before
Cycra protection
Clutch plate and clutch nuts Prox
Wössner piston needle cage
Gas sleeve
Fuel hose and carburetor vent
Levers Pro Circuit
Spark Plug + NGK Cap
Rear Wheel Spacers Prox
Complete engine seals
Pivot Works Rear Wheel Bearings
Crankshaft bearings
Smallbox containing
a superb CNC part
JT Sproket
Venhill Rear Brake Hose
And hop, throttle grip restored.
I'd say it's being watched...
Of course we're in real time now, so it's slower
It's true that it motivates me to continue to post, if I see that it interresses
In short he is back to repaint this time if I hope as it should.
I'll explain to you later ;-)
first, the cleaning phase.
I use brake cleaner degreaser, then dishwashing soap and green scocth-brite
then use car body sandpaper with the water, from different grains from 80 to 2000
and finally, I have a blow of heat gun, to give back the gloss disappeared
Can't wait to see you ride that beast at Les Pitchouns in 2020 !
Sorry to hear about the first paint attempt. Best of luck on the second go-around.
Super pumped to see the assembly when it comes to fruition.
Best,
JJM
who are you ?
Otherwise I go out claws and teeth and I kill them
Post a reply to: 1991 CR250R Project Bike Build
