06 rm 250 piston advice..
4/26/2018 9:26 AM
Edited Date/Time: 4/26/2018 11:35 AM
What changes will I have to make if I want to install the racers choice yz 250 piston in my 06 rm 250?what are the difference?is it weight ?performance?
4/26/2018 9:37 AM
change the yz to rm when ordering
4/27/2018 2:40 AM
motox766 wrote:
What changes will I have to make if I want to install the racers choice yz 250 piston in my 06 rm 250?what are the ...more
Nothing needs to be changed, AFAIK it fits right in. It is a single ring piston which means less drag.
4/27/2018 7:35 AM
Thank u turbojez.and the piston I order is the yz 250 racers choice right?would u happen to have a part number?
5/1/2018 7:26 AM
808M06640
Also this is the bike build section. This thread should be in Tech Help/Race Shop, you will likely get better responses there
@russ_69
5/1/2018 12:07 PM
RussB wrote:
808M06640
Also this is the bike build section. This thread should be in Tech Help/Race Shop, you will likely get better ...more
Thank u very much!!!
5/1/2018 12:51 PM
Order a spare ring when you order the piston, and swap it out at 20 hours. Then swap the whole piston at 40.
5/4/2018 8:35 AM
any of you guys know if i can fit a yz250 silencer to a rm250 2006? id like to get that carbon kevlar one from pro circuit !
