SIDI CROSSFRIE 2 TA
37enduro
VN
6/26/2017 3:31am
Do you looking for a good boots for enduro ? Let's check it out.
Are you planning to purchase a motorbike booth, however confused by all the diverse types? Then look no further than Sidi Crossfire 2 TA Boots. If you are not familiar with this product, then you have to read this review.
SIDI Crossfire 2 Unboxing and Review - Motocrosstime.
 SIDI Sport started in the year 1960’s producing mountain sports footwear. It was not too long until the company started focusing in cycling boots and footwear for on-road and off-road motorcycling. Thanks to the deep, intuitive skill of the company, they have become the leader in motorcycle and cycling shoes. SIDI’s exceptional balance of innovation and tradition, comfort and style, make the company sporting footwear unique in the business. And now the Sidi Crossfire TA 2 Boots is one of the best and leading motorcycle boots today.
FEATURES
The latest evolution of the company’s off-road motorcycle boot is the state of the art Crossfire TA 2 that comes with more adjustability to have a room for wider calves and remade buckles which are easy to use with a gloved hand.
Dual-Flex System:
The dual position and stitch-free upper is made from molded plastic. Due to the company’s Dual Flex system as well as the 4-floating independent harness the boots can give every rider with a perfect fit regardless of body size or utilize with knee braces.
SIDI CROSSFIRE 2 UNBOXING AND REVIEW -MOTOCROSSTIME
Easy to Adjust System:
The company’s exclusive easy to adjust calf systems permits motorcycle riders to alter the size of the boot. This system, together with long upper harness, allows this boot to have room for      rider with bigger calves easier than the past model.  This can accommodate motorcycle riders with 22 inches calf size and 14 inches above from the base of the heel.
SIDI CROSSFIRE2 UNBOXING AND REVIEW - MOTOCROSSTIME
Heel
3-extended dribs are equipped at the rear of this boot to help you in making shifts with your heel once begging a race. It is Shock resistant, rigid and anatomically shaped heel for utmost security.
Buckles
It comes with cam-lock buckle integrated with a harness memory retention system. You can adjust the straps once.
Toe
Tip toe on this boots are covered with high quality plastic material to secure the base and seems against brush and abrasion. Plastic shift as well as break lever guards is also integrated on the top of every foot area.
SIDI CROSSFIRE2 UNBOXING AND REVIEW - MOTOCROSSTIMEOther essential features:
Some other essential features of this boot are:
Upper is laminated Microfiber material
It is lined with cambrelle and Teflon Mesh.
Shin plate that is easy to replace
Dual Flex System
Replaceable Metatarsus Inserts
Anatomically shaped heel
Assembled as well as replaceable boot leg
Stitch free
TA Rubber sole
Pros
Like many other types of products available out there, it also comes with pros and cons:
Utmost security from a motorcycle boot which moves like a slipper
Easy to adjust high and fit comfort with no binding or pinching
Superb durability as well as easy to replace parts when damage
Cons
In spite of the many benefits this boot offers it also comes with drawback such as:
Firm in the toe for big feet
This is very expensive
Conclusion
All in all, the Sidi crossfire 2 TA is best enduro boosts available today. It comes with essential features that keep riders comfortable and safe when riding a bike.
Post a reply to: SIDI CROSSFRIE 2 TA
