adam8781
7/2/2017 2:58pm
7/2/2017 2:58pm
Im having a weird problem i cant seem to figure out, its on a 06 yz250, the power valve Governor by the water pump keeps spitting its pin out when the motor is running, it will run fine for a bit than lose all top end power. I pull the inner clutch cover and the 4 weight balls fall out as i remove the governor.
that pin in this pic is somehow making its way out
i tried another governor out of a friends 03 yz250 and it didn't happen again. but when i compare them on the bench they are identical in every single way,
what am i missing here? I've had 2 pins go through my motor chipping up gears, i need to figure this out asap
Post a reply to: yz250 powervalve governor pin keeps ejecting
