mackay
12/14/2017 8:11am
hey anyone with wheel building experiance ever had any trouble with tusk spokes? laced the front and spokes are way to long.. I've tried turning the hub to twist all the spokes around but not having any luck i swear there to long.
the rear i can't lace completely i can get a little less then half the spokes in then the rest won't line up? i know on cr/crfs the inside and outside spokes are different legnths and i have them in the correct position still no luck
anyone help me?
anyone help me?
When you try to thread each spoke one by one through the hub and rim you always end up with those "gotta remove 2 I just put in to get this one" issues.
Spokes are still loose all the way around nipple threaded on as much as possible
out at work at the moment cant post a photo of the rear its the one that's bothering me bit of a brain fuck
But with the rear I can get a few in with all the spokes laid out but then the next few are out of line by about 10mm
You can see that each spoke needs more angle/pitch/whatever you choose to call it, from the hub to the wheel...Best of luck and please keep us updated with your progress!
PS: As others have advised, it's easiest if you lace all nine spokes into hub first (outers first) for proper alignment/twist and then lace accordingly...
Tusk do have two size nipples one to accomodate the oversize spokes for a60s
You will need to increase the cross pattern to the stock OE 3 cross. I have photos of a 3 cross if you will like to shoot me an email. Offset is 26.50mm for the front hub.
The rear hub will be the stock 2 cross with the long spokes as the inner spokes and short spokes as the outer spokes. Depending on the rim size and year of the CR/CRF, the wheel offset will vary. What is the year and model of the bike along with the rim size?
If you ever have any questions about wheels even if it isn't our product, don't hesitate to contact us.
Cole Anderson
Racer Support Supervisor/Sale Representative
RK Excel America Inc
2645 Vista Pacific Drive Oceanside, CA 92056
Tel: (760)732-3161 Fax: (760)732-3186
Depending on the motorcycle manufacturer, the front stock OE rim comes with a slightly smaller nipple hole diameter which results into smaller nipples. Some companies like Tusk, provide different size nipples for this type of situation. You can use the stock OE spokes/nipples but it just depends how the nipple sits in our Excel rim due to the 8.5mm nipple hole diameter.
Hopefully this info helps.
Cole Anderson
thanks for the help guys really appreciate it
Post a reply to: tusk spokes excel rims issues cr/crf
