After putting new gaskets on my cr125 it started to leak coolant between the cilinder and the gasket. it leaks allot!
What can be the problem? Can it be that there is also coolant leaking in my Gearbox??
That leak would have to be caused from one of these:
A bad gasket
A warped cylinder flange due to excess tightening
A crack in the cylinder
A bad fit on the center case gasket
A bad gasket allowing coolant to get into the crank cavity
Does the bike run?
Between the cylinder and the engine case or between the cylinder and the head?
In most cases the lean should not enter the trans.
A bad gasket
Does the bike run?
Post a reply to: honda cr125 2007 cilinder leaking coolant
