Verona, PA
07 cr 125, it idles good and sounds and runs good, but I noticed when idling good if I compress the forks, or push the bike back and forth, the idle drops down to the point where it almost stalls sometimes. Idle does not fall down if I just compress the rear suspension. Seems weird right? Please let me know if this is an issue that can be fixed?
I did not notice a problem while riding the bike. It has a stock mikuni carb, 45 pilot, runs good, 144 big bore kit, new vforce3 reeds, carb boot clamps are tight. I just recently bought the bike and put it all together after cleaning everything good too. Last night I checked the float height, not with the proper float height gauge but it looked to be around 8.5-9mm, service manual says 7.5mm so I adjusted it and got it looking close to 7.5. Before I did that I noticed the bike had to be pretty much laying on the ground to get any gas to come out the overflow. After adjusting float height the gas will come out when the bike is at about a 45 degree angle leaned over, is that about right?
Thanks!
Thanks!
1. Float height may be a bit high.
2. The throttle cable routing may be causing a binding and changing the idle.
See if your idle speed changes when you just turn the handle bars from left to right and back. If so, then you have found the issue.
Like mentioned above, it can easily be messed up when turning the bars depending on how the cable is routed and the CDI on the Honda is pretty big behind the # plate there.
My buddy has the same bike with a keihin carb I'll ask him to see if his acts the same way.
Thanks
Do you have a full tank of gas in it?
Maybe it's just normal I don't know, it didn't seem to be a problem when I was riding it, I've only had one woods ride on the bike though. I just wonder if the gas sloshes around in the bowl, when I bounce the front end up and down, if that just causes more fuel to get sucked up through the pilot circuit or up out of the carb somehow and floods it out, which then I should try a lower fuel lever in the bowl/more float height when adjusting. Thanks.
http://motocrosshideout.com/2013/02/21/cr250cr125-pwk-air-striker-conve…
Here is the site I found that info on, it's very comprehensive.
Might be worth the cash to pick one up OP!
So I think I'm just gonna get a keihin carb for my bike, I can't figure out anything wrong with the mikuni carb. his keihin has no tps and I think it's a longer carb cause the air boot and subframe doesn't fit as easily. His bike has boyesen reed cage and mine has vforce3 and mine has 144 big bore.
Post a reply to: cr125 weird idle drops down when forks are compressed ?
