everything else will be boring now.
rubber side down.
don't be a bro'...bro'
arm pump spray probably doesn't work
you wont find the "powerband" part #
vitards are your new besties.
So I don't know much about bikes so I was hoping you guys could just comment some stuff I should know
Change the oil often. Clean the air filter every ride. Put good tires on . Lube the chain with WD or chain lube. Check the spokes and wheel trueness. Grease the bearings on the steering stem and rear suspension linkage. Make sure the tires have 12-14 psi in them. Make sure the grips don't spin on the bars. Make sure the throttle doesn't stick and is smooth. If you buy it used Do a topend and a (if it has one)carb clean and most likely a clutch. And I'm sure I'm forgetting stuff.
every one he ment he needs mechanical help/tips. jesh every one doesn't need to make smartazz comments. if every one would help every one and ment it then every one would be more gooder.i doubt this is a troll/fishing post ment for every one.
so heres one that every one rider should know: vital is a great forum for helping every one.
You should know that you will never ride a quad ever again.
rubber side down.
gas mixed with oil
lighter
cheaper
harder to ride fast
4 stroke-
straight gas
heavier
more expensive
easier to ride fast
Mixin' gas and haulin' ass
Post a reply to: comment something that I should know
