Yz125 shock - what years fit
Edited Date/Time 9/29/2017 8:38am
Hi guys, I'm doing a little yz125 project. When servicing the suspension I found the bearing seat at the bottom is totally worn out and oval.
Looking to find a cheap doner shock on eBay to swap this part fro. but what years fit my 08?
Is it like most parts, down to '05 or is it even longer?
I've found some 02's really cheap that would work if they fit.
Thanks!
9/26/2017 4:20am Edited Date/Time 9/26/2017 11:35am
Moderator Please remove one of the threads.
hellion
Westfield, MA US
9/26/2017 6:27am
You can probably save that shock by using a two part epoxy and new bearing. If not though, shocks from 2002 to present will fit your bike.
9/26/2017 6:35am
hellion wrote:
You can probably save that shock by using a two part epoxy and new bearing. If not though, shocks from 2002 to present will fit your...
Thanks, yes I can weld it and machine it as well but I feel it's a bit sketchy in that area and a new (used) shock is not that expensive.
So all the way from 02? Thanks!
9/26/2017 7:50am
A 2006 and newer shock would be a MUCH better option compared to the 2005 and older shocks.
9/26/2017 8:24am Edited Date/Time 9/26/2017 4:44pm
Yes but I'm looking to use the lower part only from the donor shock and put on my 2008 shock.
RockyRider
Nor Cal, CA US
3372nd
9/26/2017 9:05am
I've got one, just put it in the for sale section Cool
9/29/2017 8:38am
I live in Sweden so the shipping would be high Smile
RyanLester761
El Dorado Hills, CA US
9/29/2017 9:43am
I put a 2003 shock on my 2001 yz125 with zero issues. If you all are saying the '02-on will fit the '08, I would imagine the older shock clevis piece will fit too, (maybe from 1996 or so???) if you find one first/cheaper.
9/29/2017 11:02am
I put a 2003 shock on my 2001 yz125 with zero issues. If you all are saying the '02-on will fit the '08, I would imagine...
Yes that's exactly what I'm trying to find out. Smile
Post a reply to: Yz125 shock - what years fit
