Troy, KS
7/3/2022 2:23pm
This was in the exhaust pipe. I've checked the wrist pin bearing and all is good, I've checked the lower rod bearing and all is good, there are NO needles missing. Rod is tight up and down, and does not have excessive side play either . This entire bike only has about 5hrs on it since it was rolled off the dealer floor. Luckily the cylinder walls were not damaged. The head on the other hand is a different story. It's beat up pretty bad, as well as the top of the piston. The top of the piston smashed down and pinched the ring in the ring land reducing compression completely.
It's hard to tell in the photo but the piece that went through the motor is square in shape. It was not beat into a square either because it's a perfect square with perfect 90* angles on all sides.
I'm quite certain the ground strap was not burnt off by a lean condition judging by the base ring of the spark plug. If anything it needs to be leaned up.
Paw Paw, I agree, it DOES look like a needle from the lower rod bearing. I checked the bearing well. I spun the bearing with a awl and look through the oiling slot in the bottom of the rod. No missing needles for one, and the piece is square instead of round as well. This has certinaly got me scratching my head.
This is how I checked the bearing. Scratch awl with a hook at the end. I was able to spin the bearing and inspect all the needles in the bearing. I must have rolled that bearing around 50x thinking I missed something.
Post a reply to: YZ 125 (something went through motor)?
