Visalia, CA
1177th
So the time has come to sell my daughter's 01 XR50. Hasn't been ridden in years.
The problem is it's running lean for some reason. With the choke off snapping the throttle open results in a nasty bog, even stalling the engine. Very slow roll on can get it to rev out. Choke in the 1st position lets the throttle work much better, as does sticking my finger in the airbox's air inlet. It will start and idle fine.
The bike is rock-stock and has very, very low hours (original tires aren't even close to being worn). Fuel is fresh, air filter is clean. Air screw from 1 to 1 1/2 turns out has minimal effect. Raising the needle has minimal effect. The 3 o-rings from the cylinder to the carb have been replaced, as has the one in the carb cap. Sea level, temps from 50-70F.
Suggestions appreciated.
Turns out there's no pilot jet in those carbs, and if that circuit were clogged wouldn't it not start or idle very well? I'm having issues with 1/3+ throttle
Issue fixed, but I'm really not sure what did the trick. Pulled the carb and thoroughly cleaned all the o-ring surfaces, disassembled the carb and cleaned/checked all passages. Dropped the clip 2 notches. Annnnd it runs just fine. Not sure what changed, as I had already done all of the above.
Either way, I'm off to get the title from the DMV and then sell it. Thanks for the ideas guys.
Post a reply to: XR50 running lean
