- Pick trends
- Create a private league
- And more!
Most skirt coatings are not impervious to dirt or other effects, but some minor buffing is normal
Top piston is my last one that had 45 hours on it and ran in a damaged cylinder with bare aluminum showing through the plating in spots.
The second 2 pictures are my current piston after on 13 hours on a fresh replate.
p
That's mine with 10 hours on it. I put a vertex in and checked it after 5 hours. It's getting eaten up. Got some scratches in it already. I measured the cylinder when I got it back from millineum. It checked good. Not sure if I have a bend rod or something. Maybe the cylinder is tight in a spot or too. Gonna check the clearance with some feeler gauges while it's all torqued down. been riding it anyways runs good. Cylinder is already kinda junk now. So if it blows up who cares. Lol.
What is Wiseco ArmorGlide skirt coating?
A.
Wiseco ArmorGlide skirt coating is a dry film lubricant applied to the piston skirt. This coating helps reduce friction, improving performance, and will also help quiet the piston in the cylinder bore. This coating is permanently applied, and is not a break in coating, it is on the piston for the life of the part.
Post a reply to: Wiseco coating worn off?
