Midland, MI
Getting to the throttle body and taking the cables out was fairly easy. When I put the new one back in, the throttle now barely moves at all. I've tried numerous things to make it work, but I've had zero success. Anyone out there have any tips on what I should try next?
All obvious things I have mentioned so sorry if you have checked them but other than that I can't think of anything. Many be worth re-fitting your old cable to see if that works again and it could be an issue with the new cable.
Good luck
If your throttle won't open at all, this may be the issue.
Good luck with fix
Post a reply to: Trouble Replacing Throttle Cable on 2013 Crf450r
