Homestead, PA
6/30/2017 7:34pm
Can anyone offer suggestions on how to get the shaft within the case out of the bearing? I will include a photo of what I'm taking about. I have removed all the gears and circlips but I just cannot get that shaft to free from the bearing. Should I heat the bearing race holder screws up and just remove the whole shaft and bearing together then try to remove the bearing or can I get just the shaft out?
www.karlzracing.com
You can also try using a deadblow hammer to pound it out the other side. Maybe remove the bearing with it so you dont risk damaging the case.
Do not use heat as both the bearing and that shaft are the same material. They will expand together. Heat works for bearings and the case because the aluminum expands much quicker than hardened steel and creates a big enough gap.
Hope one of these helps
It appears the bearing galled onto the shaft. I don't understand that, though, as it's bathed in oil!! Maybe someone used the wrong sized bearing??
Oh, had to Dremel cut the bearing off in pieces as well.
Thanks, guys, for the help!
Post a reply to: Transmission Shaft REmoval
