Stripped frame repair
pastmyprime214
Vital MX member pastmyprime214
54895 pastmyprime214 /images/default/avatar/c50.png http://www.vitalmx.com/community/pastmyprime214,54895/all 11/11/16 1 http://www.vitalmx.com/community/pastmyprime214,54895/setup 7 22 6
8/12/2017 12:07 AM
I had an awesome thing happen today. As I was putting the subframe on to the frame, the bolt on the shifter side completely pulled out the threads. Now I can't torque it down to spec and not sure what to do. Researched putting in a time sert but they're expensive as hell.
Anyone have any other ideas that I can use to repair this?
Dusin791
Vital MX member Dusin791
58900 Dusin791 http://p.vitalmx.com/photos/users/58900/avatar/c50_IMG_3549_1505848385.jpg?1505848231 http://www.vitalmx.com/community/Dusin791,58900/all 07/31/17 http://www.vitalmx.com/community/Dusin791,58900/setup 1 11
8/12/2017 1:01 AM
Re tap it
Acidreamer
Vital MX member Acidreamer
48595 Acidreamer /images/default/avatar/c50.png http://www.vitalmx.com/community/Acidreamer,48595/all 08/25/15 1 56 1319 1 1
8/12/2017 5:10 AM
Re tap for a bigger bolt or use a nut on the other side.
2009 Kawasaki KX450F
2002 Suzuki GSXR 600
skypig
Vital MX member skypig
16228 skypig http://p.vitalmx.com/photos/users/16228/avatar/c50_101843880_1252836745.jpg?1294191956 http://www.vitalmx.com/community/skypig,16228/all 08/01/09 3 168 2
8/15/2017 12:36 AM
I used a timesert to fix a vintage Suzuki RM fork. Worked great, but I had to buy a kit, then another packet of the longer inserts. $$$. Still the cheapest and best fix for that situation.
What about a helicoil?
Cheap kits on eBay.
Research indicates Helicoils are actually stronger than both, the original threads in alloy, and timeserts. But timeserts are designed to be better for things which come apart regularly, like sump plugs.
Slosh 112
Vital MX member Slosh 112
42684 Slosh 112 http://p.vitalmx.com/photos/users/42684/avatar/c50_IMG_2738_1509756195.jpg?1509755299 http://www.vitalmx.com/community/Slosh-112,42684/all 03/31/14 3 26 882 54
8/15/2017 1:28 AM
Use a helicoil or recoil kit.
Instagram @_yabba_dabba_dont_
