Auburn, AL
Bike in question is a 2015 CRF250R.
Over the last two years the clutch pull has gotten stiffer with time it seems. At this point I have tried a few basic fixes. Such as replacing the clutch kit with OEM/Tusk kits, clutch cable and adjustments. To no avail of course. So here I am, back on vital. Where I hate to post without some form of a syntax guide nearby.
I was considering the Hinson relocation kit and a hydraulic clutch, but I am not able to find either of those products for my specific year model. Anyone have any recommendations?
Thanks in advance!
Thanks in advance!
Thanks y'all for the replies. I will update after the above has been attempted.
See here: https://arclevers.com/index.php?route=product/product&product_id=1&sear…
Most companies offer unique ratios; this can make a huge difference in feel and actuation.
Also, Hinson sells a "cable bracket", which may take out some of the cable flex for you:
http://hinsonracing.com/shop/?filtering=1&filter_machine-type=16&filter…
Good Luck and please keep us updated
Thanks everyone for your responses. Gonna try to give some of the costless options a try this afternoon. I'll provide an update hopefully later tonight.
Greased pivot bolt, cable slides smooth throughout, lubricated the cable, greased end barrel. Resolved any grit feeling for sure. A lot smoother pull and feel. No decrease in stiffness though.
I did however find slight relief in creating a straighter path for the cable. I zip tied the cable to the strap that wraps around the bar pad from the number plate and ran it around one of the radiator mounts. Still not ideal though.
For what it's worth, I'm running a motion pro cable with msr clutch lever and perch. The lever seems extremely long. Not sure of measurement on it. Plan to get OEM clutches ordered when I get paid Friday.
Thanks for all the help thus far and keep the ideas coming guys.
Stick with OEM.
Post a reply to: Stiff clutch fixes?
