- Pick trends
- Create a private league
- And more!
Try getting a better pic of the letters
Can be caused by attempting to run a 50:1 mix or possibly a leaking crank seal or very low compression. More info needed to be sure.
Sea level in the Northeast
Commonly called a plug chop.
The tip and upper areas of the porcelain surrounding the electrode are not the area for the true reading to be taken from.
Without a special scope to peer down to the base of the electrode insulator, the only way to truly read a plug is to carefully cut the threaded portion of the plug off, and observe the coloring "ring" made at the base of the insulator.
The plug "colors" from the base up.
If you are running pump gas, plugs do not "color" like they used to before everything went unleaded. A true reading may take many full throttle passes to achieve using a new plug.
Idling around makes trying to obtain an accurate reading pointless.
And for what it's worth, jetting requirements can change more often than you change under wear,depending on conditions.
The only other recourse is to rejet your carb to obtain a leaner fuel mix.
More oil means better piston ring seal.
buy 10 new sparkplug and do as project racer.
don´t lessen oil to get "better " plug read... lessen fuel instead
ride southwick, wareham and crowhill.
Actually using MXA's settings, just always trying to get a little better. Bike has a small low end blubber (not noticeable on track 1/8-1/4 throttle), also a low end "Knock" @ very low RPM. Again, no real issues w/bike, just trying to dial it in (has 3 hours on it)...thanks for all the input....BJ
Post a reply to: Read my plug-2 stroke newbie
