Moto-Master brake discs. Opinions?
Turbojez
PL
Hi guys, I'm in the market for some new front brake disc for my rmz 250. Thinking about getting either Moto master nitro (looks like stock) or the slightly more expensive flame model. Do you have any experience with the brand? Are there any pros to Flame design? I will be using standard, 250mm sized rotor, cannot afford an oversized kit right now. Any chance front rotor is interchangeable between rmz 250 and 450? Thanks
Idaho747
Idaho Falls, ID US
11/29/2016 11:42am
Just a question. Why switching rotors?
CarlinoJoeVideo
Portland/Los Angeles, CA US
2339th
11/29/2016 5:00pm
I'm really happy with all the Galfer stuff. I've been using thier lines, oversized rotors and sintard pads..
Turbojez
PL
11/29/2016 11:45pm
Because mine is as thin as a razor blade right now Smile
adam8781
11/29/2016 11:47pm
i wouldnt waste a dollar on a stock size front, run what you have and save up for a 270 kit, or find a cheap stock rotor as a replacement till you can afford 270
Turbojez
PL
11/29/2016 11:48pm
I've read great stuff about it and I'm planning to go this route with solid 270 galfer rotor but it has to wait as it's a way more expensive setup.
walent215
Ridgecrest, CA US
11/30/2016 4:46am
I've got the oversize motomaster flame rotor that was on my older rmz if that will work. It's in good shape .
jpatz319
Statesville, NC US
1145th
11/30/2016 5:57am
Tusk has an oversize setup that i threw on to my rmz after a crash and its working as good as the oversize EBC or braking kits I had
Turbojez
PL
11/30/2016 5:59am
Thank you for the heads up, but I would also need an adapter to make it work with an oversize rotor + I'm located in Poland so shipping would probably cost more than the rotor. How much would you want for it anyway?
I think I'll just order a standard sized moto-master flame (approx 50$ from my local parts store) and will use it while saving for an oversize kit Smile
Thank you very much for your input!
Turbojez
PL
11/30/2016 6:01am
jpatz319 wrote:
Tusk has an oversize setup that i threw on to my rmz after a crash and its working as good as the oversize EBC or braking...
Does Tusk use solid or floating rotors? Seems like solid is the way to go for MX use.
jpatz319
Statesville, NC US
1145th
11/30/2016 6:06am
It is a floating rotor
walent215
Ridgecrest, CA US
11/30/2016 6:07am
Turbojez wrote:
Thank you for the heads up, but I would also need an adapter to make it work with an oversize rotor + I'm located in Poland...
$20 ...but like you said shipping would probably cancel out any savings.
Idaho747
Idaho Falls, ID US
11/30/2016 6:51am Edited Date/Time 11/30/2016 6:52am
I have the galfer on my rmz and I am very happy with it.
CarlinoJoeVideo
2339th
11/30/2016 7:05am
I like the floating oversized. The feel is a little more progressive, not so, "on" "off" because the way it floats, you have a little play.
jhansen510
GREENFIELD, MN US
3595th
11/30/2016 4:19pm
Go with the braking non floating kit. It's like $120 for a 270 disc. Short and a bunch of other pros run this setup.
jhansen510
GREENFIELD, MN US
3595th
11/30/2016 4:21pm
After thinking that through I think it's a galfer unit. I have one on my bike and will take a look tonight.
11/30/2016 5:19pm
I just got one and can't wait to use it. Floating discs allow for expansion as the disc gets hot.
Turbojez
PL
11/30/2016 11:23pm
Yes it does allow for greater heat expansion, but I don't think there is enough heat in MX ever to make the disc warp. Progressive feel might be a big plus to floating rotors, but aren't the rivets a problem? Do they stay tight over time?
My next kit will definately be Galfer 270mm, but this time due to budget limitations I'll go with moto-master 250mm. It's winter here, I won't be riding much within the next few months, I think it'll have to do until spring Sad
jhansen510
GREENFIELD, MN US
3595th
12/1/2016 7:57pm
Galfer SKW is the one I have. Spend the extra money and get an oversized rotor. It's so worth it.
Post a reply to: Moto-Master brake discs. Opinions?
