Kawasaki KX250 Suspension
kellyraz
NZ
Age old questions -
1. Can KX450F wheels fit onto a 2006 KX250 ?
2. Is the only modification I need to make, to put KXF triple clamps and forks on the KX is the steering stop ?
Cheers
mattyhamz2
So Cal, CA US
846th
11/17/2017 8:30am
We have an 05 kx250. Took the top clamp and forks from our 06 kx450 and they mounted right up. Wheels mounted right up as well
Markopolo400
St. Paul-ish, MN US
11/17/2017 9:36am
Wheels fit, I have 2014 KX450 wheels on my 06 250.
At the same time I needed an upper shim for the top clamp in order to to put new DLC forks (07-newer KX450) on the KX250, otherwise they bolt up.
BobPA
PA US
11/17/2017 9:59am
Wheels will bolt right one as long as your bike is 06+. I have an 06 kx250 and have put my friends 2017 450 wheels on. I just did the steering stop mod to put 250f forks on my 125 (same setup as a 250), not hard, just time consuming if you want it to function correctly.
mattyhamz2
So Cal, CA US
846th
11/25/2017 8:09am
BobPA wrote:
Wheels will bolt right one as long as your bike is 06+. I have an 06 kx250 and have put my friends 2017 450 wheels on...
I put 07 kx450 wheels on my 05 kx250. They mounted right up.
Post a reply to: Kawasaki KX250 Suspension
