How to Remove a broken bolt?
2StrokeWanting4StrokeOwning
Vital MX member 2StrokeWanting4StrokeOwning
57655 2StrokeWanting4StrokeOwning /images/default/avatar/c50.png http://www.vitalmx.com/community/2StrokeWanting4StrokeOwning,57655/all 05/11/17 2 http://www.vitalmx.com/community/2StrokeWanting4StrokeOwning,57655/setup 7 12
10/3/2017 9:07 AM
So i was checking my valves and just about finished up, and when putting the valve cover back on i accidentally snapped the valve cover bolt off into my cam cap, did some searching around and found out cam caps are a matched set with the head so you can not buy just the cam cap. It is not flush and is down in there about a quarter of an inch. Any suggestions on getting it out? I ordered an easy-out kit. Any tips? Thank you so much for any help.
Squidward
Vital MX member Squidward
59325 Squidward http://p.vitalmx.com/photos/users/59325/avatar/c50_Ditch_jump_2_1503980667.jpg?1503980188 http://www.vitalmx.com/community/Squidward,59325/all 08/28/17 3 181
10/3/2017 9:23 AM
easy out kit with the left handed bits is pretty much the only way. Just take your time getting the shaft out or you may risk more problems. Then you'll end up having to drill all the threads out and re-tapping it. Not fun.
Hope for the best, Prepare for the worst.
Acidreamer
Vital MX member Acidreamer
48595 Acidreamer /images/default/avatar/c50.png http://www.vitalmx.com/community/Acidreamer,48595/all 08/25/15 1 56 1375 1 1
10/3/2017 9:32 AM
Something else you can try..
Find out the minor diameter of the threads, and get a drill bit as close to that size as you can get. Get the same size or the next size down. Use a drill press to drill the bolt out. Youll be left with only threads in that hole. Run the correct tap down the hole to remove the threads left from the bolt and you should be golden. Its very important to center your drill so you dont drill the wall of the hole. Transfer punches work well for this. Harbor freight has them.
In the future, use higher quality bolts with blue loctite or antiseize. Theres zero reason bolts should snap like that in an aluminum part. The torque on those bolts is super light. Even if there was a lot of torque, the alum threads should give way before a steel bolt snaps.
2009 Kawasaki KX450F
2002 Suzuki GSXR 600
rollin64caddy
Vital MX member rollin64caddy
46738 rollin64caddy http://p.vitalmx.com/photos/users/46738/avatar/c50_flying_tiger_theme_eight_p_40_warhawk_1427844547.jpg?1427843811 http://www.vitalmx.com/community/rollin64caddy,46738/all 03/30/15 4 220
10/3/2017 4:57 PM
I used to work at a chevy dealership a few years ago and when we would get exhaust bolts breaking off in heads we would send them to a automotive machine shop to get them extracted. not sure how they did it or how much it was. when the heads came back, you'd never know a bolt had been broken inside the threads. might call around machine shops and see what they can do.
BobPA
Vital MX member BobPA
40845 BobPA http://p.vitalmx.com/photos/users/40845/avatar/c50_Engine.F_1455853935.jpg?1455853535 http://www.vitalmx.com/community/BobPA,40845/all 10/31/13 1 79 5039 8 1
10/3/2017 6:19 PM
Left handed drill bit set and a small easy out. Should not be a problem. Just TAKE YOUR TIME, no need to rush stuff like that. New sharp drill bits make your life a lot easier.
Jason Anderson FTW
Vital MX member Paw Paw
31735 Paw Paw /images/default/avatar/c50.png http://www.vitalmx.com/community/Paw-Paw,31735/all 12/24/11 1 471
10/3/2017 7:45 PM
I would almost bet you can work that out with a small screwdriver or fine punch. The bolt would have had all the pressure on the shoulder and after being broken off the tension on the threads will have been released and you should be able to just walk it out with out drill. It's worth a try.
526
Vital MX member 526
15118 526 http://p.vitalmx.com/photos/users/15118/avatar/c50_112776150_1241467529.jpg?1294190360 http://www.vitalmx.com/community/526,15118/all 05/04/09 20 941 10
10/4/2017 5:16 AM
This is very true and sometimes even a blast of compressed air with get it moving.
