Hone Tool - Supermini
Rob357
NH US
What do you guys like for honing tools for the small bore of a 53mm YZ Supermini?
I'm seeking exact brand names as there seems to be a LOT of them out there.
Any tips or favorite practices on honing with piston change would be welcome too.
Tracktor
The RTF/Amboy, WA US
3/24/2017 10:15am
If Nikisal (sp) no honing needed/recommended from what I have seen. I usually just use green scotchbrite pad and made sure cylinder was extremely clean. Sometimes a light scuff with emory paper to remove residue. Then dry assemble and run one heat cycle to make sure seated and run hard after that. We were getting 15-20 hrs out of our 105 and the pistons looked fresh coming out and ran strong................
Rockinar
Katy, TX US
3/24/2017 1:54pm Edited Date/Time 3/24/2017 6:50pm
The honing debate is like "What oil is best?" debate. You have one camp that recommends it, they call it "deglazing". The other camp is strictly against it.
I say leave it alone. No honing. If its that bad, get a new cylinder or have it replated. Cylinders on Super mini are cheap. Some gentle green Scotchbrite pad to clean things up a little, no issue. No way I would be sticking a hone it it. Ask people what happens when the hone catches on the ports.
adam8781
3/29/2017 10:49am
you can do a quick deglaze/hone with 240-320 grit sand paper at all.
the rigid hones are best but not cheap and work best with an oil bath
Jake_CR250R
Ozark, MO US
3/29/2017 10:23pm
You should not use a ball hone. The proper way to do it would be a rigid hone and honing oil, and just a few quick passes.
Acidreamer
Mansfield, OH US
3/30/2017 1:24pm
I vote dont touch it. Just get it replated. If you arent a machinist who knows exactly what youre doing theres a high chance of messing it up
Post a reply to: Hone Tool - Supermini
