IT
Hi.
I was searching for solutions to arm pump, and some people said that a tight fitting glove helps. Mines are really baggy so I was looking at those 3 pairs.
What's the difference between Airs and SE pros? Air for hot weather and SE for cold?
How do they perform compared to Deft Family gloves? I've seen mixed reviews on them, most say they're the best gloves they've ever tried and some say they're the worst.
Deft family has two different styles, velcro closure or slip on. I prefer the velcro slightly over the slip on just for personal preference when fitting but still have several pairs of each. The palms are all one piece with only a double layer on the inside of the thumb. I do use grip donuts but no problem with blisters. I would say these are my favourite gloves to ride in, snug and no bunching. The TLD Air has a top section material that allows air flow, more than any other glove I've worn. If you have sweaty hands, these are the ones for you. TLD SE Pro is basically the air without as breathable of a top section.
All three pairs are very similar. I wouldn't say that the SE is for cold weather it just doesn't vent/flow as much air into them. I like my Defts just due to the lesser amount of material and fit it of the glove. All three gloves are snug fitting and cut down on the bunching giving myself a better feel for the bars. As far as reducing arm pump, maybe the less bunching cuts down on hand fatigue and in turn arm pump?
If your looking to reduce arm pump, I say more forearms at the gym and better stretching before moto.
Post a reply to: Gloves: TLD Air vs TLD SE Pro vs Deft
