Fork Seals?
YZfan1230
I noticed some oil leaking a little on my 16 YZ 450 and i noticed alot of the times a seal is just dirty. I want to start by cleaning it to see if it remedies the problem but I don't have a sealmate to clean it. Does anyone know what I can use to clean the seals without having to remove anything?
karlz
7/15/2017 1:22pm
You could use a feeler gauge, but be careful not to tear the seal or push more dirt in to the seal. To be honest I would have a new set of seals on standby.
www.karlzracing.com
mxandy963
Hesperia, CA US
7/15/2017 1:55pm
You can also use a tear off. A lot easier on the seal and lower slider. Make sure to drop your dust seal first.
imoto34
TN US
3179th
7/15/2017 4:45pm
Do you pressure wash your bikes? I use a normal seal saver and have got many to stop leaking.
YZfan1230
7/15/2017 6:27pm
Now that you brought it up yeah! I never thought of that actually, I don't have a seal saver and there isn't anywhere nearby that sells them. But now that I think of it the pressure washer could have been the problem
omalley
Snohomish, WA US
7/15/2017 8:10pm
If you end up changing seals, make sure you check the slider really well (run your hand over it to feel for any nicks). Otherwise you'll be changing out the new seals in short order. Minor nicks can often be smoothed with very fine wet/dry sandpaper and some WD-40.
lumpy790
York, SC US
7/16/2017 8:28am
omalley wrote:
If you end up changing seals, make sure you check the slider really well (run your hand over it to feel for any nicks). Otherwise you'll...
I run my finger up and down the tubes to feel any sharp edges. Any decent suspension shop should do this too.
I have a set of small jewelers files and find the slightly rounded one works well to get the edge burrs out.
Idaho747
Idaho Falls, ID US
7/17/2017 9:49pm
You could also cut a water bottle
7/18/2017 11:50am
If your seals are leaking and over 20 hours. Its time for new seals and bushings. Its really easy to do .
Post a reply to: Fork Seals?
