Saratoga Springs, NY
I'm learning how to rebuild bottom ends..very low hr 92 rm 250, had been sitting a long time, crank is original, not rebuilt, very tight. I split cases to replace main bearings & seals & water pump seal. Did everything by the manual, froze bearings, heated cases, bearings dropped right into cases nicely, I gave them a light tap with a socket. Crank dropped in to bearings very nicely, I used crank puller just to make sure crank was in bearings/cases. Very thing went together really nice & easy. Crank spins like butter. Problem: when I tighten down drive gear bolt, the crank spins but not as freely as when bolt is not tight. I have read other post on this topic & I tried using rubber mallet on crank ends, but does not seem to help...thanks for any advise...
Also, if you had the transmission and crank assembled in the right case, sometimes tightening the left case bolts will push/slide the crank toward the right due to main bearing drag.
Post a reply to: Crankshaft drag advise
