Cone Valve-AER48-4CS Ride Height?
CarlinoJoeVideo
Vital MX member CarlinoJoeVideo
41118 CarlinoJoeVideo http://p.vitalmx.com/photos/users/41118/avatar/c50_jessy1_1471467436.jpg?1471466703 http://www.vitalmx.com/community/CarlinoJoeVideo,41118/all 11/30/13 3 53 http://www.vitalmx.com/community/CarlinoJoeVideo,41118/setup 96 4137 44 5 1
10/1/2017 3:17 PM
Hey guys, so today I took off my cone valves and put my 4CS on my 2016 KTM125 for an off-road trip. I noticed the upper tubes are shorter than the cone valves.
For example I run my cone valves at 2 lines up in the clamps.I run 105mm sag. The 4CS will need to be flush in order to get the same balence.
What height do you guys run on your forks and sag? Thanks!
LumpDog841
Vital MX member LumpDog841
55218 LumpDog841 http://p.vitalmx.com/photos/users/55218/avatar/c50_V8_1481571558.jpg?1481570625 http://www.vitalmx.com/community/LumpDog841,55218/all 12/12/16 http://www.vitalmx.com/community/LumpDog841,55218/setup 2 167 5 1
10/1/2017 3:23 PM
Running mine on the second line for the CV forks, same as I ran with the AER. For sag I'm running around ~107 mm, though it's been two weeks since I checked it.
CarlinoJoeVideo
10/1/2017 5:26 PM
Cool, have you ever compaired the upper tube Length between the 2?
LumpDog841
10/1/2017 7:05 PM
I honestly haven't. Though they appear to be exactly the same, but I don't have actual numbers to back that up. One weird thing though is the CV forks seem to fit better in the xtrig clamps...maybe better dimensional tolerance?
Giygas
Vital MX member Giygas
50290 Giygas http://p.vitalmx.com/photos/users/50290/avatar/c50_red_bud_1452364938.jpg?1452364395 http://www.vitalmx.com/community/Giygas,50290/all 01/09/16 20 314
10/3/2017 7:50 AM
I got my 4CS forks revalved by Craig at Enzo. He told me to run the black part on top of the forks even with the triple clamp. The fork was moved down slightly from the stock position.
MotoMatt_928
Vital MX member MotoMatt_928
53784 MotoMatt_928 http://p.vitalmx.com/photos/users/53784/avatar/c50_Byron2_1496938970.jpg?1496938862 http://www.vitalmx.com/community/MotoMatt-928,53784/all 08/13/16 1 http://www.vitalmx.com/community/MotoMatt-928,53784/setup 1 70 1
10/3/2017 10:22 AM
I ran my 4CS flush at the top, but my AER48 I run at the 3rd line. Sag at 105mm.
CarlinoJoeVideo
10/3/2017 3:20 PM
Very interesting! I wonder if the 4CS are shorter than the AER.
Thanks for the info guys.
Lynch
Vital MX member Lynch
46471 Lynch http://p.vitalmx.com/photos/users/46471/avatar/c50_Arlanda_283_1426354092.jpg?1426353614 http://www.vitalmx.com/community/Lynch,46471/all 03/14/15 3 86 6
10/3/2017 9:15 PM
I will check when I get home after work.
FRANZINI499
Vital MX member FRANZINI499
48481 FRANZINI499 /images/default/avatar/c50.png http://www.vitalmx.com/community/FRANZINI499,48481/all 08/17/15 http://www.vitalmx.com/community/FRANZINI499,48481/setup 5 67 1 1
10/3/2017 9:57 PM
Edited Date/Time: 10/3/2017 9:59 PM
Yeah the AER forks are usually about 10-12mm longer than the 4CS!! Its kind of interesting that they would have such drastically different fork lengths, but not change the chassis to supplement... It makes you wonder if the chassis was originally developed to accept the shorter fork, and realized that they needed the extra length to work out some bugs? Or if they designed it for the longer fork, but wasn't ready to release the AER fork to the rest of the world? Questions that someone higher up on the KTM food chain would have to answer I'm guessing...
I think I saw an MXA article a while back supporting this, I'll go through the archives to see if I can find anything!
FRANZINI499
10/3/2017 10:14 PM
Found it!! April 2016 Issue of Motocross Action!
CarlinoJoeVideo
10/4/2017 6:17 AM
Yeah 1/2 inch is a big difference.
FRANZINI499
10/4/2017 9:56 PM
Huge difference!!
Digger29
Vital MX member Digger29
30444 Digger29 http://p.vitalmx.com/photos/users/30444/avatar/c50_11111166_1604018196548831_2446724603716701395_o_1433855518.jpg?1433855158 http://www.vitalmx.com/community/Digger29,30444/all 11/02/11 5 39 http://www.vitalmx.com/community/Digger29,30444/setup 40 1422 9 17
10/5/2017 7:45 AM
I ran my cone valves on the 3rd line on 15.5 FE450 because of the length difference between the 4CS and the cone valve forks. I ran my cone valves on my 16 & 17 on the 2nd line because the cone valves are very close to the same length as the AER fork. I actually tried the AER cone valves on the 3rd line this weekend and went from 105mm of sag to 108 and the bike worked really well on a very fast and very choppy track. It settled better in the turns and tracked very good in the rutted turns and was super stable at speed.
CarlinoJoeVideo
10/5/2017 8:23 AM
Cool, do you like steering with the front or rear of your bike? I'm going to try some different sag numbers tomorrow.
Digger29
10/7/2017 6:22 AM
I like to steer with the front end but definitely use both ends depending on the track and the situation, why?
CarlinoJoeVideo
10/7/2017 7:59 AM
Just wondering for bike set up and style of riding. I'm all front end, I like it to track hard and turn like front wheel drive.
I ran 105-107 yesterday with forks at 2 lines. I think that's the money spot. Went back to my base suspension setting and I did some tweaking on my clickers, she is set up really good right now. I'll take this setting to a few more tracks and see how it holds up.
Digger29
10/7/2017 8:35 AM
Edited Date/Time: 10/7/2017 8:37 AM
I've been running 104-105 on all 3 of my 450s and when Powerband came to the Racer X event in Maine a few wks ago he set mine from 105 to 108 and that's where it's been for the last 3 weekends. He was very surprised at just how rough the track was. I've been telling Billy for 3 yrs that our tracks get very rough here in New England. He came over to my RV at the end of the Fridays practice and told me to pull my stuff and he going to revalve it based on what he's seeing track conditions wise. I'm very pleased with the revalve and that he finally believes me :-) I'm going to leave the forks on the 3rd line for tomorrow at NHMX.
CarlinoJoeVideo
10/7/2017 4:15 PM
I could see 108sag and 3 lines up being similar feel to 105-106sag and 2 lines up but the ride feeling taller off the ground. What do you think?
What spring rate and how much preload do you guys run?
I'm 160lbs, 4.7 spring with 2 clicks of preload.
Vadim
Vital MX member Vadim
57640 Vadim http://p.vitalmx.com/photos/users/57640/avatar/c50_mx1_1507480016.jpg?1507479228 http://www.vitalmx.com/community/Vadim,57640/all 05/10/17 1 http://www.vitalmx.com/community/Vadim,57640/setup 8 19 1
10/7/2017 6:49 PM
I ran my CV on the 3rd line on 16.5 250 SXF FE, and 108 sag.
I'm 180lbs, 4.8 spring, 1 click of preload, setup by powerband.
I tried 4th line, it is good for corner, but a little unstable on high speed.
Excuse my english - it's my second language!
slothy
Vital MX member slothy
54522 slothy http://p.vitalmx.com/photos/users/54522/avatar/c50_File_Mar_02_3_23_20_PM_1488487194.jpg?1488486232 http://www.vitalmx.com/community/slothy,54522/all 10/09/16 2 75
10/9/2017 7:54 AM
whats considered a drastic change in sliding the forks up? 1 line? 5 lines?
CarlinoJoeVideo
10/9/2017 10:35 PM
I think if you go 2 lines in either direction from where you are it's big.
Just saw this photo of marven- looks like he's 3 lines up.
CarlinoJoeVideo
10/9/2017 10:36 PM
