I have a ktm 250 sxf 2011 efi. I was out last weekend on the bike and did one 20 min session. I went out to do another session 20 mins later and on lap in the bike started bogging and then cut out. It started again but bogged and cut. I walked it off track and let it cool down then fire it right back up but as soon as it's warm it Boggs down and cuts out. Iv changed the air and fuel filter, emptied the tank out, checked for bare wires. I haven't changed the plug yet but not sure it could be that.
Has anyone had similar issues or know of anything else to try before I put some money into it??
Thanks in advance.
Thanks in advance.
Make sure your fuel tank vent line is good and not clogged.
I would also do an ohms test on the coil.
I had an injector get partially plugged on my 14 ktm. The bike would start and idle fine but if you went to accelerate hard it would fall on its face. If you tried to rev the bike up in neutral it would just bog out. My mechanic popped the air filter off and shot some starting fluid down there and all of a sudden the bike would rev no problem. Checked fuel pressure and it was good so that basically left the injector. Threw a new injector in it and no problems for 30+ hours.
Thanks again!!
Post a reply to: Bogging issues help!!!
