Tucson, AZ
Who are you guys going through for revalving of the AER 48 forks? I picked up a TX300 to run in the desert and like it on just about everything but low speed chop/braking bumps. I'm trying to find a balance between the forks working well on whoops and g-outs, not diving in turns, but also not beating me up on slower stuff. It seems to be a happy medium that might be tough to find.
The shock was way too soft initially, so I basically had it revalved to TC250 specs and it feels better, but of course required me to run more pressure in the fork to balance the bike out. I resprung for my weight before I ever rode the bike. I'm coming off of a 16 YZ450F that has been set up by Smart Performance and works extremely well, so perhaps my expectations of this WP suspension is too high.
I'm leaning towards FC but have reached out to Kreft and plan on calling Race Tech here shortly. I'm not looking to have the "just buy some cones" discussion because I'm too poor for that, unfortunately. Thanks for the help and forgive my ignorance on suspension related stuff.
Race Tech does with their gold valves, I believe.
I decided to go with FC. I will be having them do a revalve on both ends with a bladder kit and Xtrig adjuster on the shock. I am having them update the air piston while its apart. I'll report back after I get it done and get some time on the revalve.
Have you ridden with your setup yet? Any base valve changes to go with the new mid?
Erik
As stated before, I'm coming off of a well set up 16 YZ and have no complaints about this suspension after FC did their work.
Right now thats my biggest complaint right in the middle of the stroke on the forks in any kind of bumps its really harsh and I have had to go down so far in the pressure i feel like the valving needs to be changed.
I'll be sending my FX450 suspension to them for the same treatment.
Thank you for the info man.
What did it cost you if you don't mind me asking? You can PM if you don't want to put it up on here.
Huge improvement for me.
Braking bumps were my biggest complaint, and now I can blast right through them!
I can ride longer and pick any line now. Perfect for me. Intermediate vet mx
Post a reply to: AER 48 Revalve
