Boulder, CO
Hi All,
Just bought a bone stock 2014 RMZ450, and I'm wondering what the best upgrades/fixes to make so the bike lasts forever (engine and frame). It has plenty of power stock, so looking more for things that will make it last longer as opposed to go faster. The last bike I owned was a 2005 CRF250, and it was bullet proof, but a lot cheaper.
So far my list is:
-High Temp radiator cap
-Skid Plate
-Radiator braces
-Heavier clutch springs
-Any other must haves or known issues?
I'm planning on changing the oil and filter every ride, as well as checking the valves every 25 hours, but any other maintenance items you've learned from experience or are just good general ideas would be great.
I'm planning on splitting my time evenly between track and trail here in Colorado (5k feet elevation) with a few summer races thrown in.
Thanks! Also, I tried searching for this in the forum but if I missed something let me know
So far my list is:
-Skid Plate
-Radiator braces
Change your Piston, bottom end and bearings at a reasonable interval.
I would recommend changing the oil filter at every oil change though, or using a steel filter and thoroughly cleaning it. Also make sure you remove and clean the lower strainer filter (by the gear shifter) at ever oil change. Remove the springs and thoroughly clean the magnet and strainer.
A good skid plate is a good addition, keeps the engine cases and frame well protected. Always best to remove it when you clean the bike though as they can trap dirt and hold water easily.
I wouldn't say heavier clutch springs are a necessity, I'm still using the stock clutch and think its pretty damn good since I removed the judder springs and fitted some custom spring seating washers.
Be sure to run the bike after every wash to dry out. Also keep an eye on the plug and plug cap, it can get pretty shitty down there after a while.
I've put over 40 hours on my RMZ now and its been perfect with no faults at all. Use good fuel, keep on top of your filters and oil, pay close attention to your hour meter and replace engine parts at sensible intervals and you will have the bike for a long time!
I'll start with this stuff and keep on top of the maintenance and hopefully be riding for a long time
Post a reply to: 450 Upgrades for Engine & Bike longevity
