2017 ktm 350sxf ---puff of smoke
Matt Barber
Vital MX member Matt Barber
57908 Matt Barber http://p.vitalmx.com/photos/users/57908/avatar/c50_IMG_4520_1496116730.jpg?1496116432 http://www.vitalmx.com/community/Matt-Barber,57908/all 05/29/17 7 5
10/5/2017 8:49 PM
So I started the bike cold and let it idle for 2 min and I heard the motor start to sound like it was struggling,,, I reved it a bit and it blew a huge plume of white smoke then it all cleared up real quick..... WTF was that? So I just rode it easy for a few laps and no issue.
Any body experience this ???
slipdog
Vital MX member slipdog
16124 slipdog http://p.vitalmx.com/photos/users/16124/avatar/c50_Screenshot_2017_09_09_at_8.47.50_AM_1508679215.jpg?1508679132 http://www.vitalmx.com/community/slipdog,16124/all 07/25/09 9 1 31 7113 53 9
10/5/2017 9:40 PM
White smoke usually is from a coolant leak.
nage0139
Vital MX member nage0139
48062 nage0139 http://p.vitalmx.com/photos/users/48062/avatar/c50_IMAG0287_1436844772.jpg?1436843953 http://www.vitalmx.com/community/nage0139,48062/all 07/09/15 1 16 83
10/5/2017 9:43 PM
My initial thought is that you may have sucked some air filter oil, but I've never actually seen or tested that theory. It could explain it all, but again, just a theory.
RCF
Vital MX member RCF
4784 RCF http://p.vitalmx.com/photos/users/4784/avatar/c50_0611171249_1_1502895901.jpg?1502895426 http://www.vitalmx.com/community/RCF,4784/all 04/01/08 13 66
10/6/2017 5:41 AM
Like mentioned above if you just put a clean air filter in that's probably the culprit , or you have a leaky valve seal which isn't a big deal as long as you're not leaving a trail of smoke behind the bike when you're riding I wouldn't worry about it.
CarlinoJoeVideo
Vital MX member CarlinoJoeVideo
41118 CarlinoJoeVideo http://p.vitalmx.com/photos/users/41118/avatar/c50_jessy1_1471467436.jpg?1471466703 http://www.vitalmx.com/community/CarlinoJoeVideo,41118/all 11/30/13 3 53 http://www.vitalmx.com/community/CarlinoJoeVideo,41118/setup 96 4006 44 5 1
10/6/2017 6:44 AM
I had a valve seal start to go at about 80 hours on my 16 250f and it would smoke almost like a 2 stroke. Ran fine other than that but as stated above it was a constant smoke not just 1 puff.
Squirtlege
Vital MX member Squirtlege
51142 Squirtlege http://p.vitalmx.com/photos/users/51142/avatar/c50_23_1507133462.jpg?1507133421 http://www.vitalmx.com/community/Squirtlege,51142/all 02/23/16 1 91 1
10/6/2017 8:12 AM
Edited Date/Time: 10/6/2017 8:12 AM
I've also had this happen from going too ham with the filter oil... usually a direct result of the amount of beers consumed prior to oiling my filter.
BobPA
Vital MX member BobPA
40845 BobPA http://p.vitalmx.com/photos/users/40845/avatar/c50_Engine.F_1455853935.jpg?1455853535 http://www.vitalmx.com/community/BobPA,40845/all 10/31/13 1 69 4762 8 1
10/6/2017 9:25 AM
My 450 has done this a couple of times too. It acts like it loads up like a two stroke a bit, clean it out and it is good to go.....Only happens when I use the "choke"
Jason Anderson FTW
Matt Barber
10/6/2017 9:30 AM
That's it... I just put in a new filter the night before.... and had a few beers
Thanks for the help
MotoMaverick989
Vital MX member MotoMaverick989
54605 MotoMaverick989 http://p.vitalmx.com/photos/users/54605/avatar/c50_IMG_1001_1505316820.jpg?1505315914 http://www.vitalmx.com/community/MotoMaverick989,54605/all 10/16/16 1 47
10/6/2017 2:29 PM
White smoke can also be raw fuel. It’s what diesels do when an injector starts to have an issue and dumps a lot of fuel and the engine can’t even begin to burn it and the injector usually hangs open injecting on the other 3 strokes. Black smoke is the result of being overfueled but the engine can consume it. White is still in its raw vapor form and usually results in a hydro lock. Could’ve been a hiccup with the ignition or injector.
Squitlege
Vital MX member Squitlege
51141 Squitlege http://p.vitalmx.com/photos/users/51141/avatar/c50_IMG_1754_1507156050.jpg?1507155208 http://www.vitalmx.com/community/Squitlege,51141/all 02/23/16 1 63
10/6/2017 2:31 PM
Thanks for the help
I wasn't trying to be a smartass. It could be a bunch of things. Was just relaying my personal experience.
BobPA
10/6/2017 6:29 PM
I should add that mine only did this on colder mornings where I had to crank the bike over slow a few times to warm the battery up.
Jason Anderson FTW
Squitlege
10/7/2017 12:19 PM
Shoulda poured more beer on it bob
