2017 KTM/Husky airfilter cage ripping foam filter
Pirate421
MA US
8/12/2017 11:33am Edited Date/Time 8/14/2017 2:51pm
Changed the filter in my '17 FC350 today after eh first ride and noticed a small tear in the inside foam. Not all the way through just a chunk missing. I then put a new filter I had bought on the cage and same tear appeared when I removed it. I noticed at the tip of the center point on the cage has a bur from the plastic mold that seems to be ripping the foam. Luckily I caught it before it could have ripped all the way through. I filed it down and seems to have helped but wanted to give a heads up to other owners to check this. Hoping whatever small chunk of foam didn't get sucked into the engine. First one was definitely how it came from the factory.
8/12/2017 2:31pm
That small of a chunk wouldn't hurt anything if it went through your engine bro.
seth505
SD, CA US
1048th
8/14/2017 10:35am Edited Date/Time 8/14/2017 10:36am
I hate how the top center pierces into the filter, I sanded mine down a bit but it's still too thin and should have been built with a wider shelf to sit on. Definitely good to make sure your cage doesn't have any little jagged pieces on top there that will cut easier like you mentioned.
MotoMatt_928
Jacksonville, FL US
8/14/2017 2:51pm
I run the NoToil cage with no issues. 30 hours or so.
Which brand are you using?
Pirate421
MA US
8/14/2017 7:29pm
It's the stock cage that had the bur on it. I filed it down and smoothed it out. That tear is from the original filter installed from the factory and it also did it to a new twinair I test fit. It is a small chunk but due to the weird design I'm sure it could have ripped through after a few changes. I am not fond of this new design of the new cage.
mxb2
Bowie, MD US
8/14/2017 8:16pm
Get the no toil screenless cage filter $50,. End of problem
BobPA
PA US
8/14/2017 8:31pm
KTM two stroke cage and a quick filing only costs you $15
mxb2
Bowie, MD US
8/14/2017 9:55pm
Not taking a chance on metal shavings to save $$.
seth505
SD, CA US
1048th
8/15/2017 7:57am
There is no metal, it's all plastic
mxb2
Bowie, MD US
8/15/2017 9:55am
My bad, should have more clear, not all bikes use plastic.
seth505
SD, CA US
1048th
8/15/2017 10:05am
Right on, I thought after I posted you were probably thinking of a screened cage you'd have to cut out or something.
mxb2
Bowie, MD US
8/15/2017 12:08pm
Yessir
BobPA
PA US
8/15/2017 6:42pm
The two stroke cages do not have the backfire screen. Someone makes a plastic one aftermarket pretty cheap too.
mxb2
Bowie, MD US
8/15/2017 9:03pm
No toil.And I used a rm250 one in my rmz.
BobPA
PA US
8/16/2017 7:00pm
That's the one
Post a reply to: 2017 KTM/Husky airfilter cage ripping foam filter
